Which way do I turn crank aux pulley nut!!!!!???? URGENT
should be anti clockwise, been a while since iv taken one off tho
They can be buggers to get off. Id suggest you replace them while your at it.. dont cost much from vaux
ok got it off!! second question!!!! URGENT!!!!!! It seems the engine mounting has to come off to replace the aux belt? Any other way or ideas? thanks
support engine with a jack and undo mount
Hey thanks folks, just taken the water pump off! Didnt realise it can be fitted totally the wrong way?! Is there anything to line up? I know theres those little cast cut out bits but they mean nothing when lining it up!!?
there should be a notch you line it up. if you dont then the cam belt could fail!
Take a pic and i could help more
