Hey folks, dont have the time to get a haynes manual but what Im looking for is the easiest way to remove the head on a 1.6 8v. Ive removed the airbox, exhaust, rocker cover etc, coolant pipes. What is scaring me is the access to the stuff I need to get off. For example Ive undone the top row of inlet manifold bolts but the bottom row seems somewhat impossible!!? Also the cambelt, how the hell do you gain access to the crankshaft!??!? Ive removed the top half section of the belt casing but obviously theres some big wheel sensor low down on the crankshaft which covers up the bottom half of the belt!?
Im also replacing the waterpump, is this an easy job and how is it held in because my pump seems to have no holes for bolts!!
