no spark..........
have u checked the connecting plug that goes onto the ignition amp? This is what happened on mine because the connectors had pushed down so not making a connection
SAME MATE!!!! SAME!!! thanks for screw n coil tho bud, if no one else knows, then auto electrician will be called on end of month, dont wanna do that as it will probably cost £200 notes but no one else has any ideas, ive tested it all, read codes, still nothin!!!
A good auto-electrician should only need an hour to find the fault, and the one i use costs £45 for the first hour
i had the exact same thing and im a auto sparky ..... this anoyed me for about 2 weeks .. i ended up changing the engine loom and hay presto started first time .
so, autosparky came round, says ignition amp not workin, although we managed to get a spark from it, and its attempting to fire up now, but it still wont fire, everytime it attempts to, the cogs go bACK half a turn as it doesnt fire, just nearly does, coughs and splutters...ideas? (where nearly there lee69!!!)
